Gus
Find & Select Criteria Sets Exporting
In ArchiCAD 20 the Find & Select is a little different, making it particularly useful to create one's own Criteria Sets that one can use over and over rather than having to manually click through all the options every time. It appears as though we can export one criteria set at a time using the pull-down button to the right of the Criteria Set name. I have not found a way to export all of my criteria sets at once. Does anyone know if there is a way to do this, or if this is something that happens automatically somehow?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
DGSketcher
Legend
I think it is currently stuck with one criteria set at a time...
http://helpcenter.graphisoft.com/guides/archicad-20/archicad-20-reference-guide/interaction/selectio...
One for the wish list - "Export all Find & Select criteria sets" ?
