We value your input!
Project data & BIM
Font and Favorites Default
Is there a way to setup defaults for fonts, drawing title fonts and styles, section tags, etc? Is this something I need to setup with a template?
1 REPLY 1
Erich
dharch,
Without anything selected double click on the desired tool. Change the settings to what you would like them to be by default. This will then work until you change a setting. But presumably things such as font, text style and text sizes will not often be touched.
I would save this to a template file and use this for all new projects.
HTH
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
