‎2004-06-21
03:24 PM
‎2025-01-30
12:25 PM
Molinda Prey
‎2004-06-21 03:43 PM
‎2004-06-21 04:20 PM
Matthew wrote:No not my custom menu (as far as I know) but the standard shortcut menus in Archicad.
I assume you are talking about your custom menu shortcuts. These are stored in a preferences file in:
User Home > Library > Preferences > Graphisoft > AC8.1.0 V2 (or whichever version you are using).No "user home file" or "Preferences" in the library file.
They may have been over-written if you installed an update.No update has been done to this Mac since Friday.
I believe that the shortcuts are stored in the "ArchiCAD Lasting.Prefs" file.have look for file but can't find it.
If you have office standard shortcuts you can copy this file from someone else's machine otherwise you may need to find it on a backup. (You are backing-up your user folder aren't you?)
‎2004-06-21 05:06 PM
‎2004-06-21 05:21 PM
Bryn wrote:if you're not seeing these files, it sounds as though something is wrong with your user account on the machine and could also possibly explain why archiCAD was having reading it's defaults out of the application folder . . how are you logged in? admin user? server user? check the permissions, etc.Matthew wrote:No "user home file" or "Preferences" in the library file.
and then you can come over here and sort ours out too.Matthew wrote:
If you have office standard shortcuts you can copy this file from someone else's machine otherwise you may need to find it on a backup. (You are backing-up your user folder aren't you?)falls of seat laughing. Err this company doesn't seem to understand the principle of standards and backups, I've only been here 3 wks and seem to hit a brickwall every time i ask for company standards.
Once i've learn't Archicad properly and they are paying me the right wage then I'll sort all that out.
‎2004-06-29 02:53 PM
‎2004-06-29 03:44 PM
Kevin wrote:hey kev. how's things? (apart from upgrade problems
Why oh why doesn't the update installer put up a banner recommending that you copy your prefs folder before updating? (rhetorical question).
Oh well, now Ctrl+I for Intersection...are you left handed or have you just got long fingers?
‎2004-06-29 04:03 PM
are you left handed or have you just got long fingers?Laptop keyboard...
‎2004-06-29 04:48 PM
Matthew wrote:Matthew, great help, but for Win XP users:
I believe that the shortcuts are stored in the "ArchiCAD Lasting.Prefs" file. If you have office standard shortcuts you can copy this file from someone else's machine otherwise you may need to find it on a backup. (You are backing-up your user folder aren't you?)
