ā2010-07-06
07:51 PM
ā2023-05-26
11:10 AM
Rubia Torres
ā2010-07-07 12:14 AM
ā2010-07-07 02:48 AM
ā2010-07-07 04:38 AM
Ray wrote:We need more information, are the floors that moved module files of their own? Or are they mirrored?
I saved the entire as-built as a multi-story module. The story heights in the new plan are fine but the 2nd floor and the basement each moved west about 30 feet.
Ray wrote:This is probably because the whatever you used to trim the 2nd floor elements using SEO were not included in the mod.
Also, it appears that the Solid Element Operations performed on the 2nd floor of the as-built are not in effect in the new plan. The SEOs on the 1st floor remain in effect, however. I don't know if this is related to the offset problem.
ā2010-07-07 07:53 PM
ā2010-07-07 08:18 PM
Ray wrote:Correct. Once the building is correctly stacked the roofs will again trim the walls as the relationship is still there.
As for the SEOs, they were done on the walls of a shed dormer. The dormer roof appears in the HLM and so do the walls, but the walls are anchored to the second floor, which has moved 30 feet away from its roof; I'm guessing that that dislocation was enough to suspend the operation of the roof on its target walls? [/img]
Ray wrote:There have been some anomalies with mirrored elements in module files that is why I wondered if at any time you mirrored the basement and 2nd floor (the elements that moved 30 feet). Did you?
What do you mean by "mirroring?' I haven't deliberately mirrored anything, but then anything is possible.
[/img]
ā2010-07-07 08:20 PM
ā2010-07-07 11:13 PM
ā2010-07-07 11:20 PM
ā2010-07-22 10:45 AM
