‎2009-07-13
11:01 PM
‎2023-05-26
09:01 AM
Rubia Torres
‎2009-07-13 11:43 PM
‎2009-07-14 03:29 PM
‎2009-07-14 05:12 PM
‎2009-07-14 05:25 PM
‎2009-07-14 07:55 PM
ksymons19 wrote:Every time you want to update the master file you should just publish (saving as every time is a huge waste of time and effort--that is what Publisher is meant to do/avoid) your modules from your source files. You transfer attributes between PLNs via Attribute Manager --you should also choose one file (it can be, say, the site plan file) to work as the 'Attribute Creation File' --all materials, layers, layer combos, line types, profiles, etc., get created there and transferred to the other files as necessary. If somebody messes up the attributes in some file, you can just overwrite everything from your 'Attribute Creation File'.
A further update on my experimenting - attribute manager will NOT recognize MOD file format?[…]My best solution right now is to do all of our design in PLN format and then save as both PLN and MOD file to keep the master file updated. It really is annoying to save multiple times to keep both nested and hosted files updated at the same time. Perhaps I overestimated the capabilities of MOD files?
‎2009-07-14 09:26 PM
‎2009-07-15 08:29 AM
ksymons19 wrote:I am not sure I am following exactly what you are doing but basically if you are 'saving as' modules, especially when it is not some crazy temporary one-off thing but something you modify and update every now and then, you are not using the program right.
It's not that I am disagreeing with publishing modules, it looks like your set up works fabulously for you, I just don't see it fitting in this project.
‎2009-07-15 03:32 PM
‎2009-07-16 03:20 AM
