Project data & BIM
How are zone sort in the pull down menue?
iggiv
Hi there!
I’ve been trying to figure out how to sort categories from the pull-down menu, but I’m stuck. My main goal is to have them short and in alphabetical order so I can quickly find the one I need.
I’ve searched online, but I couldn’t find any clear instructions. I don’t want to sort them in a schedule, just in the drop-down menu.
Does anyone know where I can find some guidance on this? I’d really appreciate it!
2 ACCEPTED SOLUTIONS
CosminF
Have you tried a number on the category code before them and see if they will be sorted in ascending order?
Cosmin Furdui - architect @ Wincon, based in Romania
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
Ricardo Lopez
Hi @iggiv
Zone categories have a Category Code that can be used for sorting.
You can see them all together in Options> Element Attributes> Attribuute Manager> Zones
Try to sort them by Name and then change their Codes accordingly.
Regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
CosminF
Ricardo Lopez
Hi @iggiv
Regards.
Hey Cosmin and Ricardo! I was sure I had tried this before, but somehow it worked before, happy to say this time it did. I knew I was doing something wrong and Graphics couldn’t make it complicated. Thanks a bunch! This is the solution I was looking for!
