Project data & BIM
How to draw zones for a correct IFC export and usage.
Gonzo666
Hello everyone,
I have a question regarding the height and position of the zones in the model:
Should zones be drawn from finish floor to finish ceiling or should they be drawn from concrete slab to concrete slab and then subtract the finishes with a formula on the property manager?
The advantage of drawing from finish floor to finish ceiling is that I get the clear height directly from the room, without the use of formulas. I can also getter wall area from the room and use it for a cost estimation.
I do not know how this affects the whole ifc Modell when it comes to recognizing the MEP elements that don’t touch the ifc zone.
Is there a standard and defined Ifc workflow for drawing and exporting zones?
I hope I explained myself correctly.
I appreciate your help.
AC 27
0 REPLIES 0
