Project data & BIM
How to find missing library part?
Hi Everyone,
Every time when we open a project or log in to TW project the library loading report will show you how many missing library we have for this file but i just could find it anyway even i turn on all the layer.
Has anyone know a simple way to look for the missing library part?
Is it a library part that could have been placed in a section or elevation or even on a layout?
Also check in all storeys as well.
Thats what i try to avoid because we have over 70+ detail sheet and 50+ elevation and section.
If i have to go through them all it will take me whole day. Thats why i wonder its that any quicker way of doing this, because i just want to delete the missing library part
I am afraid you will have to open each section/elevation/detail/worksheet etc. manually, turn all layers on and see if you can spot the missing objects.
Unless someone knows something I haven't realised.
The good thing is if you are just going to delete the objects then it really doesn't matter as they won't be showing.
So if you can put up with the missing objects message then all is fine.
But if you are like me I hate having missing or duplicate parts even when they aren't going to affect anything.
Especially when others will be working on the file.
