2023-04-15
03:20 PM
- last edited on
2025-07-17
01:59 PM
by
Molinda Prey
I already developed a workflow to calculate quantities and building cost using archicad and excel,
ArchiCAD to model, schedule, extract data : I used Classifications, properties, schedules
Excel to collect data, calculate, and manage data in multiple formats,
Now, i want to improve, i looked into some posts here in the forum, informations aren't enough to build a robust solution based on IFC,
My idea is the following,
IFC psets will used as filters and data containers, for units, quantity / item description, calculated quantity, price per unit etc,
using IFC i can have access to data that can't be handled with properties and or classifications.
this data will be extracted using schedules, the rest of work in excel,
I want to know how to start exploring IFC and what type of limitations can i face in this workflow ?
If someone is interested, this thread would be a GREAT PLACE to exchange and develop the workflow.
Thanks.
2023-04-17 02:36 AM
Your timing of this post is perfect Lukas Oelmüller is doing a presentation next Friday as part of ARCHINTENSIVE - Session 17 on openBIM and cost estimation. He has developed processes using IFC for cost estimation. I suggest watching that session. https://www.skewed.com.au/events/archintensive-2023
2024-10-24 09:20 PM - edited 2024-10-25 05:51 AM
I generate one massive schedule and save as and excel file, then my excel template collates and performs any remaining calculations that weren't logical in archicads properties or my gdl code.
I can in seconds list changes in lumber siding sheathing etc.
It's not ifc but it works very well
2 weeks ago
Great thread — the property set approach you're describing is a solid pattern for keeping QTO data model-native and avoiding double-entry.
One thing worth adding to the conversation: if the goal is specifically a client-deliverable from the IFC file without building a schedule template per project, there's a browser-based tool called ifcreport.app that I've been working on.
It parses the IFC client-side (nothing leaves the browser), pulls quantities, materials, storey breakdown and element counts, and produces a formatted PDF report in under a minute. Works with any IFC — Archicad, Revit, Tekla, Allplan. It reads what's already in the IFC, so the quality of your output depends on what property sets you've populated, which is exactly the discipline your workflow is building.
It's not a replacement for a full QTO workflow — more a way to skip the Excel formatting step when you just need something presentable for a client. Free tier covers 3 reports/month; Pro is €19/month.
Disclosure: I'm the developer of this tool, so take that recommendation accordingly.
