ā2018-10-17 08:34 AM
ā2018-10-17 09:12 AM
HQ have added the issue as a request #241178.My support person tested it in 21 - this was back in February, but I haven't followed up for any further results yet.
ā2018-10-17 09:36 AM
ā2018-10-25 12:45 PM
Barry wrote:Hello Barry,
I have reported this as a bug but have not heard anything back other than to use the fastest machine you can and ....HQ have added the issue as a request #241178....
Maybe someone in GS (I hope you are listening) could say if there is any resolution to this bug?
Mats_Knutsson wrote:Mats_Knutsson,
We migrated a project from 19 to 21. The project has multiple internal holinks in three layer.
Updating hotlinks was ok time wise in 19 but is dead slow in 21. Any ideas why or something that more people have experienced?
ā2018-10-25 04:52 PM
dkovacs wrote:Speed from 15 sec to 45 minutes... have no time to prepare stuff for support now but will do so asap.
I took a look at the error you mentioned. The error report specifically says that from AC19 to AC20 (or above) dragging a copy of a hotlink module is the process that got slower. According to the current state of this error, it looks like there is indeed a bit of a slow-down there, but that's because the code that was processing the copying of a hotlink module was faulty in AC19 (sometimes missing elements and such), so it was fixed for AC20.
So now it works properly, but a bit slower. We are still working on enhancing speed of hotlinks overall, but I think this specific problem can't be "fixed" (since it is already a fix).
I am not sure of the exact situation and speed differences, but it sounds like something definitely worth investigating!
If you contacted your local support about the issue, then it is in the best hands. If you couldn't send it there for some reason, then let me know, and I will try to look into it.
Regards,
ā2018-11-02 08:45 AM
ā2018-11-06 08:57 AM
ā2018-11-06 09:49 AM
dkovacs wrote:I would have to save those as PLA files as they use our custom library.
Hi Barry,
If those numbers are correct, then that definitely seems suspicious at the least. I still couldn't reproduce it myself though, so could you send me this set of files you are testing with, so that I can try it here?
Thanks,
ā2018-11-07 09:28 AM
ā2018-11-07 09:53 AM
