2023-04-11
08:33 AM
2025-01-02
03:04 PM
Molinda Prey
Spacing and number are possible.
You can also check the number in the schedule.
2023-04-11 09:06 AM
An array for what exactly?
Do you want to show/adjust the spacing in the schedule?
That is not possible, unless all of those beams are actually one object with a parameter that controls the spacing.
If they are separate beams, then there is nothing you can do to schedule the spacing.
2023-04-11 09:28 AM
If you know your total length, you could use the Edit => Distribute function. Then if you group the objects, you could then move the end ones to modify to total length and redistribute.
