‎2005-11-30
01:36 AM
‎2023-05-26
03:29 PM
Rubia Torres
‎2005-11-30 06:46 AM
Laura wrote:you're in 'attribute manager'? if you don't press 'apply' the layers will still actually be in archiCAD's memory - hence not letting you write-over the index numbers.
I'm simply trying to create a template file, and it would be really nice to have consecutive Layer IDs!
‎2005-11-30 08:01 AM
~/archiben wrote:Being quite anal myself I have also lined up all the index numbers in some of my templates.
being quite anal in that i like to see things nicely ordered and lined up, i can quite understand what you are doing, but i just want to check: youdoknow that you can pretty much ignore those index numbers don't you?
‎2005-11-30 08:32 AM
Matthew wrote:i even hesitated before i made the decision whether or not to write the caveat
... I am sure that you also know that "pretty much" ignoring the index numbers can get you into trouble with fills in library parts and endless headaches with layer combinations (which require the indexes & names to match).
‎2005-11-30 04:56 PM
‎2005-11-30 05:09 PM
