Lucian Laculeanu
Layer management - INDEX question
Here is a topic that starts to be a nuisance.
Ever since I started working in depth with ArchiCAD, I functioned based on the observation that making new layers or importing new layers, will be a process that always places them at the end of the roster, independent of the gaps that are in the Index field. This is how some companies end up after multiple changes with indexes in the 800s... This never failed. I never was able to find a setting that could control that.
Unless, I wanted to append by index, this was a given.
I ran a quick test in 27 to verify this in a simple solo and a "hot-linked" instance and the results are the same.
However, I get people that tell me that when they make layers, theirs just simply go and fill the gap.
What is your experience? Am I going crazy here? (You don't have to answer this one...)
Here is how I made my quick test:
Operating system used: Mac Intel-based 16.6.1 Sonoma
AC 7-26 (current 27)
iMac 3.6 Ghz 10Core Intel Core i9 / 12b GB / AMD Radeon Pro 5700 XT 16 GB / Ventura 13.4
https://globularcreative.wixsite.com/home
1 Solution
When placing a hotlink module or copying & pasting between files ...
If the attribute number does not exist in the host file, then it will simply be created with the same attribute number as in the original file.
If the attribute number is already used in the host file, but is for a different named attribute, then a new attribute will be created with the first available 'empty' attribute number.
If a user creates a new attribute, then it will become the highest attribute number + 1, it won't use the first available 'empty' attribute number.
Go to post
2 Replies 2
Lucian Laculeanu
I'll take that...
