Thomas Nymann
Layer sorting by "Name" in AC 26
Hi there.
it seems the sorting of Layer Names in AC 26 is a little different than in previous versions (besides handling attributes in folders etc.)
The way AC sorts layers, seems to have changed.
Previously you could use multiple digits, to create "subcategories" after a Main layer e.g A21---- and then sublayer A214--- Etc.
Since AC 26 Layers are sorted as "real numbers" (I guess) meaning 3-digigt numbers will  always be higher than 2-digit numbers thus A214--- will be placed below at the bottom of the list, instead of "just" under A21---- Please see attaced picture for reference:
(This almost a National standard regarding Layers and their names)
Is this an intended change/feature, or an unlucky consequence of the new Attribute System?
Below is a simple screenshot showing the differences from AC 25 to AC 26
Kind regards
Thomas
ASUS ROG I9 12900H 🙂 - RTX 3080ti (16GB) - 32 GB RAM - Ryzen 7 1700X 3,8GHz. - GTX 1080ti 11 GB- 16GB RAM
AC 13 +
14 Replies 14
Legat
This new sorting method ruins any layer sorting in projects migrated to archicad 26. It hinders any workflow that the whole office - though wrong - got used to. A simple "old method" checkmark would be greatly appreciated. Even if this sorting method is "natural", it wasnt before. We can't rename hundererds of layers that all technical planners adopted to already. This is a big problem for dozens of projects in our office.
Oleksandra Vakariuk
Hi @kristoftihanyi and @Legat,
Thank you both for your inputs!
I understand that this adjustment can be frustrating, therefore I added a request for the above-mentioned feature to our database as WISH-12780.
Kind Regards,
Oleksandra Vakariuk
Technical Support Engineer
kristoftihanyi
Dear Oleksandra,
Is there any progress regarding this functionality? I couldn't find this among the community wishes, so I assume it's in some internal list, that's not publicly available? I'm really looking forward this improvement in the HUN edition.
Thanks
Eduardo Rolon
If you read above this was already fixed in march 2023.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
kristoftihanyi
Dear Eduardo!
I was referring to the ability to turn off this new 'natural' sorting and reverting to the legacy method. This thread was marked solved because the problem was identified as an intentional new feature. Oleksandra wrote that the request to turn it off was added as wish-12780 to a widhlist somewhere. I was referring to this.
