Mirroring Zones and their stamps!
Hi, I am having massive problems mirroring zones stamps and getting them to be perfectly mirrored.The project I am working on is an apartment complex where many of the apartments are perfect copies but mirrored (So I have each apartment saved as a hotlink and then intend to mirror the hotlink). I have put zones with stamps into rooms and everything works fine in the original hotlink but once mirrored, some of the stamps just go haywire. I thought it had something to do with the zone's reference/origin point but I have tried rearranging those ad nauseam. The solution I have used until now is making a manual textbox with the zone information so that I can manipulate it as I want, but being able to use those heckin' zone stamps shouldnt be this hard!
Is there anyone who has a solution for this?
9 Replies 9
Try to integrate your zones in modules rather than in the master file.
The zones of each repeated module can easily be:
- be moved in X, Y and Z
- receive a symmetry
- to be modified in the master register by SOE
- dissociated in a nomenclature
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Hi, thanks for the reply! But the zones are in the module/hotlink file. the picture was just an example. So If I have an apartment hotlink with zones and just want to mirror the hotlink, some of the zone stamps don't mirror correctly, everything else in the hotlink mirrors fine. I will put a picture here. As you can see some of the zone stamps are mirroring correctly but the "Bod" one and the "Stue/kjøkken" one aren't. (The Right hotlink is the original in this case and the left one is the mirrored hotlink)
Ok
Don't use automatic zone please
I don't use it any more because of the weird stamp they create !
It's not a real solution but don't use automatic stamp and all will be fine
Christophe - FRANCE
Archicad 15 to 29
Lingwisyer
Guru
I remember having this issue a while back, but I cannot remember what I actually did to solve it... have you tried changing the text alignment?
Ling.
Thanks for the replies, but the issue persists even if I have manually placed the zones. I have attached an image and I have tried many different things. I am no closer to figuring out a solution. And changing the text alignment in zone stamps is not possible (I think).
Did you use a new version of Archicad between the beginning of your project and today ?
One of my customers had this problems by using AC22 then following with AC21 by saving a previous pln version
Can you check if you are using a favorite zone about a previous Archicad or something like that ?
Can you verify with a all new zone without any personal parameter ?
Christophe - FRANCE
Archicad 15 to 29
Lingwisyer
Guru
Text alignment can be found under the default stamps settings. Though it appears to not cause your issue with my mirrored stamps...
Ling.
Hey Christophe. I believe this was the problem. The project was started in Archicad 21 and I have migrated it over to Archicad 22 and the stamps that I have been re-using from the AC21 version were the ones that were misbehaving. I tried to make absolutely new stamps instead of reusing old ones and the mirroring works. Now I need to change the old stamps to new and it should be alright!
Thanks so much for spending time to help me with this!
With pleasure
Christophe - FRANCE
Archicad 15 to 29
