If I understand right you clicked the Annotate button in the Schedule and placed those JPGs there.
Drawing data you create in a generated Viewpoint will not appear in a host file when the given project file is placed as a Hotlinked Module (HLM).
I mean, if this happened then everything you have drawn as fills, lines and annotations e.g in a Section Viewpoint would be propagated into a Section Viewpoint of the host file into which the file is placed as HLM.
The Interactive Schedule is a
I think the rule is that only the Floor Plan content goes through when placing HLMs.
