‎2014-10-07
05:02 PM
‎2023-05-20
12:07 AM
Gordana Radonic
‎2014-10-09 02:47 AM
‎2014-10-09 02:53 PM
‎2014-10-09 05:40 PM
‎2017-06-01 07:02 PM
‎2017-12-14 01:05 PM
Da3dalus wrote:Probably one solution is to categorize your changes in layers and turn on-off the layers in the views. That way only the visible changes will be taken in consideration.
This system works nicely if you have multiple revisions going on, but only one revision in progress on each sheet. It's easy in the Navigator or the Book Settings to exclude any Layouts from the current Issue. Then create the next Issue.
Unfortunately, you cannot produce Issues out of order, or have 2 open at once. I recently got stuck in such a situation where I was waiting on Engineers to complete a significant Revision, the number was established, and then I had to send out a couple of quick construction Revisions with a later number. I wound up reverting to text-and-object manual means.
From what I can tell, if you have two clouded areas (Changes) set up on a single Layout, and you want to only include one on the current Revision/Issue, then you can't do it without erasing and later re-drawing the other Change clouds.
I'm writing up a wishlist, and one major improvement of this tool would be enhancing the connection between the Change Manager and Issues/Revisions. It's always seemed to me like a Change should be linked directly to a specific Revision manually. Right now, the process is somewhat automatic, and inflexible. For me, I'd like a simple mode: Change = Revision = Issue.
