‎2008-04-30 10:13 PM
‎2008-05-01 01:07 AM
‎2008-06-10 12:34 AM
‎2008-06-10 05:49 AM
what's wrong with 2 separate files...? They only really need to be together in the site plan, no? It seems to be an unnecessary complication...!
‎2008-06-10 10:53 AM
‎2008-06-10 10:56 AM
Laura wrote:absolutely. ignore the storey ID tag - name each of the storey levels as you want them. using two files would cause no end of complication for what is a simple task for archicad . . .
Create a Story for each level:
‎2008-06-10 12:35 PM
which is always a pain and logistically problematic (i.e. windows, doors, level dims, plotmaker, etc...)clearly this is not the case with AC10: plotmaker-gone, d/w are solved with multistorey walls, level dims ??? - having a storey for each level = no problem... I can not see your point here mate.
‎2008-06-10 12:45 PM
‎2008-06-10 04:31 PM
JWD wrote:Apparently, what is "simpler" for you is "more complicated" for others...
... so all I'm really saying in the end is that I really like to simplify wherever and whenever possible...
‎2008-06-10 11:20 PM
Laura wrote:Apparently SO!! ha ha...! I dunno what to say with this difference of opinion - unless I'm just not understanding the situation. I normally feel it's a lot easier to set up separate files for separate buildings which have (even slightly) different sectional characteristics... clearly there are MORE THAN TWO different solutions to the problem that would be satisfactory - and it would really depend on having a detailed look at the actual project, and the person working on it, the team, etc etc..JWD wrote:Apparently, what is "simpler" for you is "more complicated" for others...
