cocoloco
No folder on computer with archicad backup files/autosaves
Hi! I followed the manual on accessing the archicad/graphisoft autosaves from today - but it always ends at folder application support. In that application support folder, there suppose to be Grpahisoft folder but it is not. I tried also to look for different graphisoft folders with no luck.
Any advice?
Operating system used: Mac Intel-based
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
Setup info provided by author
1 Solution
The Backup file is always in the same folder where you saved the PLN file (if you checked to save backups in the Work Environment dialog).
About Autosave files: Check the Data Safety and Integrity page of the Work Environment dialog. You can see the location of the Autosave folder there.
Go to post
cocoloco
Oh I see ok, I thought there is some other folder with autosaves. thank you
