Project data & BIM
Office Standards + Attribute Manager
Hi
I am currently trying to set up an comprehensive Office standard + template file in AC11. After adding + removing various old + new attributes (and simultaneously reorganizing the attribute #s), the pop-up menus for lines, materials, fills, etc, is completely illogical, i.e. it is organized neither by attribute # nor alphabet. Needless to say it makes it pretty hard to find what you're looking for in a long list. Why is this?
Also, the pop-up list will have a completely different display order between cut, cover, and drafting fills. Can s anyone tell me how to correctly organize attributes? Or point me in the right direction?
Thanks
1 REPLY 1
Lines and Fills are organized alphabetically by type (first, simple line types/fills alphabetically, followed by symbol line types/fills alphabetically), this you cannot change (unless you want to force a specific order by renaming all of these attributes).
Because of the havoc it can wreak with Library Objects (and the fact that AC recognized most Attributes by their Index Number, not their name), I don't recommend messing with existing Attributes unless you know what you are doing. Search the Forum for other posts regarding this matter.
