Denis,
How far along in the process are you? ArchiCAD/Constructor models are generally pretty lean. Its the Section/Elevation/Detail windows that cause PLN files to grow.
I would avoid the curtainwall objects in the current version of Constructor and perhaps try a different scenario using "empty openings" inserted in a wall. These should better allow you to attach recipes and derive quantities in Estimator. Abstracting the building envelope in this way should help.
If you are still concerned about the "complexity" of the model you might consider these points:
Most ArchiCAD objects now have parameters that control the complexity of the object. Many also have a switch to turn shadowing off.
A plug-in called Polycount is available from the Help Menu. Navigate to the Goodies web page and install Polycount in your Add-Ons folder. This will let you adjust complexity parameters in the model as a batch.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
