Project data & BIM
Problem with listings
Ciprian1503
Good evening!
How do you do the automatic sizing?
It doesn't work for me.
Also, how do I manage to select 2 different sizes to copy and paste? This is also valid for other objects.
On a wall 40 cm wall, i want 40 to appear , not 0,4. How can I do this?
Operating system used: Windows 10
I can’t understand your subject or question…   You say listings but I think you mean schedules?  What do you mean by automatic sizing?  Or are you talking about dimensions?  What do you mean by selecting two different sizes to copy/paste?  Example?  (No program allows copying of two different values, so this is hard to understand,)
AC 28 USA and earlier   •   macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Indeed, I refer to the problem with the dimensioning of the elements.
Example : I select one objects and after to the second step i can t select another objects. That s what I wanted to say.
I resolved this with ... shift.
And about dimension I resolved with help lines.
Setup info provided by author
