Problems after update to Mac OS 10.4.3
After updating to OS 10.4.3 and then relaunching Archicad 9 with the latest hotfix, I can't use the shift key to constrain angles, the option key for pick up and put down attributes, and the command key for trim etc. I have tried a new and reset all file with the same results. Other keyboard shortcuts seem to work fine. Blood pressure is rising as I use these keys constantly. Has anyone else had this problem or does anyone have any ideas. Thanks.
7 Replies 7
Dwight
Please don't be offended if I suggest a restart.
Sometimes the system gets confused. I occasionally have the machine ignore certain keyboard commands when in ArchiCAD. A Force ReLaunch of the Finder seems to fix it.
Dwight Atkinson
__archiben
sdodd wrote:
After updating to OS 10.4.3 and then relaunching Archicad 9 with the latest hotfix, I can't use the shift key to constrain angles ...
as dwight said - often a restart will fix up things like that. when you carry out any installation at system level it's also advisable to repair permissions and perform a general clean-up followed by a restart - it just blows the dust off and leaves things shiny and fresh . . .
do a search - there are several threads relating to OSX clean-ups and running post-installation system tools here in this forum . . .
HTH
~/archiben
b e n _ f r o s t
Thanks for the suggestions. I have tried all that as well as reinstalling archicad but to no avail. The only solution I have found to work is to go back to os 10.4.2 - everything works fine then, but I don't like not having the latest os update. Still open to any other suggestions before I have to do an archive and install. Thanks
I figured it out. I think. It appears to be a conflict with a part of Quicken that opened at start up to automatically update accounts. I deleted that from start up items and got the functionality back. Thanks for your help.
christiandcdc
I have the exact same shift-constraint, option-command issues that started when just after I installed Quicken 2006 and enabled the Scheduled Update feature that pops up upon system start up. Unfortunately I can't seem to remove/disable it. If it worked for you, I hope it will work for me. What exactly did you do? Thanks in for any help.
Christian
MacBook Pro
Mac OS X Lion 10.12.4
2.5 GHz Intel Core i7
16 GB RAM
AC 20 USA
Eduardo Rolon
go to
-> system preferences
-> accounts
-> select user
-> login items
-> remove offending item from list
I think that should do it
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
christiandcdc
Eduardo, sdodd, thanks for the insight and help. Quicken was the culprit. Once removed from login and restarted, everything works fine.
MacBook Pro
16 GB RAM
AC 20 USA
