Project data & BIM
Project Info Categories
John Dunham
Does anyone know if there is a way to change the default categories in the 'Project Info' window?
John
___________________________
AC 25 (3002 USA Full) / Vectorworks Designer 2021
Cadswift Infinite Openings / Infinite Joinery Add-ons
27" Retina 5K iMac w/ 4.2 GHz Quad-Core Intel Core i7 and 32 GB 2400 MHz DDR4
OS X 10.15.7
Not that I know of. The content is a bit of a mystery... I exported all Info to an XML file to study and it's not even clear how the XML data gets loaded into the appropriate categories. Some internal magic happening.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
John Dunham
Thanks Karl, it would be nice if there was a bit more flexibility with the categories, I think it would be a relatively easy feature to add in...
John
OS X 10.15.7
