Guillermo1
Property
Hello, to create a Price property for furnitures, is better  to be a string property or legth or number? in order to make a summation
Operating system used: Mac Intel-based sonoma
1 Solution
runxel
Strings (text) can not be totalized. Use a "number" for prices, those can be summed up in a schedule.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Go to post
3 Replies 3
runxel
Guillermo1
number can have a dot every 3 digits?
runxel
Yes, if you set your PC up to display that, then that's possible.
Sadly it is tied to the region/locale settings of the computer you're on – so the colleagues might see something else.
