Project data & BIM
Purging Attributes
gdford
I just realized that it sometimes takes 4-5 purges in the attribute manager to get everything purged that can actually be purged. Does anyone understand why this is so? I have never read anything that said that purge may need to be repeated several times to actually get the job done.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
2 REPLIES 2
Lee Hankins
As far as I can work out it is because as some attributes are purged it then frees up other attributes to be purged. So if a Building Material is purged this then frees up certain Surfaces that can be purged in the second round, this then in turn frees up Fill Types that can then be purged in  a third round and so on.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Yes - that is my assumption as well - One would think that this would happen in the background when we press the purge button... or there could be a note that pops up that says " hey guys and gals you might need to press purge 5 times in a row to really do a purge".
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
