2021-07-09 11:23 AM
Solved! Go to Solution.
2021-07-09 05:55 PM
2021-07-09 11:40 AM
2021-07-09 11:44 AM
2021-07-09 11:52 AM
2021-07-09 12:20 PM
Podolsky wrote:
1. You are loosing all custom library parts you created, because previous version ArchiCAD cannot read newest version of GDL (even if inside of the script all commands are old).
2021-07-09 01:13 PM
2021-07-09 02:31 PM
Barry wrote:Oh! This is great news! Thank you a lot for that hint.
A small clarification here.
Unless the object is saved in the Embedded Library.
Then it will convert back to older versions unless it uses a new command that isn't in the older version.
I have done this quite often to save an object back for an older version.
2021-07-09 05:27 PM
2021-07-09 05:55 PM
2021-07-12 01:34 PM
