ā2021-07-09 11:23 AM
Solved! Go to Solution.
ā2021-07-12 05:49 PM
LaszloNagy wrote:You would still potentially be faced with annotation losses, but a very good idea. I would reinforce it with a Graphic Override that highlights the changed elements the same way as missing textures or inverted elements are highlighted. At least then you might be able to find the changes rather than the fairly anonymous reporting we get in the Check & Repair process.
Here is one use case I saw:
I just have an idea or suggestion. When saving to the previous version, it would be great to have a checkbox "Save elements that would be deleted to Morphs". This way, any geometry or elements not present in the previous version would be converted to Morphs, which would convert back to the previous version.
Also, any library part existing only in the latest version would be converted to Morph.
This way no geometry would be lost. Of course, parameters would be lost, but the geometry at least would be there.
ā2021-07-12 06:40 PM
ā2021-07-12 08:29 PM
DGSketcher wrote:Great idea! Please make a wish topic, Laszlo
ā2021-07-12 08:41 PM
another Moderator
ā2021-07-13 10:53 AM
Karl wrote:
Great idea! Please make a wish topic, Laszloš
ā2021-07-13 03:15 PM
