BURAKEREL
Re: "Coordinate Dimension 25.gsm" showing wrong Project Origin coordinates
Thank you Algimantas. Actually I discussed this issue today with GS distributer's Technical support. They told me that we should use the survey point as origin and survey point dimension.gsm. We worked actually opposite direction. We started the layout as in World Coordinates and put the Survey point its correct location to avoid errors because of the models distance to the 0,00 point. at first as I showed the object works well and gave correct coordinates bıt when the model gets bigger and new elements were added it corrupted and we reloaded it then the tool lost its coordination with the origin. now we are going to move our model to the AC origin and locate the survey point somewhere and define its location  and we will change our coordinate object with survey coordinate object.
1 Reply 1
Our survey point is always rotated towards NORTH direction it is never equal to 90 degrees, depending on project. This way whole coordinate system gets rotated and it has nothing common with Project Origin coordinates. This is not first time bugs arises with new Survey Point function 😞 I understand that this could be fixed in some strange manner, we can even write coordinates by hand.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v29 INT / NOR
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
