‎2005-12-20
05:12 PM
‎2025-01-29
03:22 PM
Molinda Prey
‎2005-12-20 05:31 PM
‎2005-12-20 05:41 PM
‎2005-12-20 05:49 PM
TomWaltz wrote:That sounds rather interesting.. could you do me a favour, and post a section screen shot so I can see what the looks like?
We usually use composite slabs which contain the sheathing and truss space. We also use composite walls The slab is extended to the inside face of the sheathing on the exterior wall, then use Solid Element Operations to subtract the slab from the wall, so the plywood extends all the way to the second floor, while the stud and drywall stops at the bottom of the floor trusses. Also, if the second floor trusses change size, the SEO is a live relationship and will cut off the studs at the new height,
‎2005-12-20 06:26 PM
‎2005-12-20 07:13 PM
Josephus wrote:No, just the most common, or the lowest, or the highest..... it doesn't really matter. Life is easiest when slabs, roofs, and walls can be inserted at 0'-0" to the current story, but there are tons of examples where that is not possible.
Tom, you mention keeping roofs on a separate story. I typically have roof plate heights all over the place, do I create a separate story for each/all roof planes starting at their respective heights, or ??? (Marc Holt is going to be posting something along this line in the "working in AC" section, so I apologize that this question is somewhat duplicative, but I'm mentioning it here since we're on that general subject.)
‎2005-12-20 08:33 PM
‎2005-12-20 08:40 PM
