ā2021-10-09
02:11 AM
ā2022-10-04
02:25 PM
Oleksandra Vakariuk
I'm new to using the Revision History Object. I have added it to the master plan layout, have linked all changed to the appropriate wall etc but changes will not show in this table, even though I can see them in the project Indexes change list.
Have searched high and low for a solution and no doubt I am missing a step but have no idea what it is. Hoping someone can assist as I need to issue the documents today
Solved! Go to Solution.
ā2021-10-11 07:55 AM
thanks - solved issue with IT support. I had put the object in the title bar rather than the master layout. Knew it would be simple but talk about wasting so much time looking for a solution over the weekend
ā2021-10-09 08:30 AM
Hi Robyn. Here's the detailed workflow:
https://helpcenter.graphisoft.com/user-guide/128650/
ā2021-10-10 05:37 AM
Thanks, have looked at this but will re assess. The issue is not showing up on the revision history object, they are obviously not linking to each other
ā2021-10-11 06:31 AM - edited ā2021-10-11 06:32 AM
Do also note that replacement of the word "Issue" with the word "Transmittal" has created a fair amount of confusion of late.
