Sections don't show in AC18
In the midst of modeling an existing home, placed section lines and then pushed 'open section' and nothing shows. My layers are correct...using the Bobrow template, never had this problem before....
ok, i figured this out, the "renovation filter" keeps changing the setting from "existing" where I set it; to new...WHY DOES THIS HAPPEN, Can't I just have it set as existing and be done with it....
The Renovation filter will be saved with a View, whereas if you just select the section marker and "Go to Section" you will not necessarily have the correct filter assigned.
