Project data & BIM
SOLVED!
Show volume of all selected elements
ananas
Is there a way to simply show volumen of all selected components in Archhicad or maybe any of free bim viewers?
2 ACCEPTED SOLUTIONS
Solution
Gerry Leonor
You can use the Element Information palette:
add a shortcut or dock it to the side of your window if you want even quicker access.
i don't know about the BIM viewer tools though...
AC25 | Win10 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
Solution
Gerry Leonor
then i would suggest creating a schedule for these elements.
5 REPLIES 5
Solution
Gerry Leonor
Hi Gerry, this is perfect thank you!
the only thing is, I have many elements and I have to calculate the sum up volume. in Element Information pallete, there are volumes of seperate elements shown and I need a sum-up.
Have you tried Interactive Schedules?
These can show totals as well.
Solution
Gerry Leonor
Thank you both answers are correct!
At the end I have simply checked the sum up vollume in a free ifc viewer bim vision.
Interactive Schedules would also work
