Tom Krowka
Stacked zone name
Any way to stack zone names so two words would be one over the top of the other & centered? They would not be adjacent to each other. Seems like adjacent is the only way to do it. Version 24.
Thanks, Tom
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
3 Replies 3
Does the zone stamp you are using have the option to adjust the number of characters per line or maybe the width of the text box?
In some cases you can add \n (carriage return) to the text and it will split it.
I just tried with the zone name and it locked my computer and said I didn't have enough memory.
It may not work with zone names (I know it does with other text in GDL objects).
I think my PC needs some maintenance.
So save first before you try this.
Tom Krowka
Am using the 02 24 zone stamp standard with AC. Don't see anyplace to adjust # of characters or width of text box. Also....what is \n carriage return. I can't get any response from AC trying any number of combinations with that phrase. At least it didn't freeze up. Room abbreviations will have to suffice unless any other ideas pop up.
Thanks Tom
[email protected]
www.walshkrowka.com
Does this setting help?
I still use an old zone stamp that allows the number of characters to be set rather than an actual width.
I just tested in 24 and \n does work, but the rest of the stamp will not recognise the new line.
