Project data & BIM
SOLVED!
is there “Unit Volume" in Schedule
Hello,
In the Schedule, there is "volume" showing the total quantity of 3 pieces of same type of elements, but is there a colume showing unit volumne of each element, in addition to the total volume?
If not I have to list each element one by one
Thanks
1 ACCEPTED SOLUTION
Solution
Erwin Edel
As a workaround you could probably create a property for the volume and convert the numeric value to a text string, which would stop the schedule from adding them up.
STRCALCUNIT ( {Property:General Parameters/Gross Volume} )
This should work as the Expression needed to convert Gross Volume to a string property.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
2 REPLIES 2
Solution
Erwin Edel
www.leloup.nl
Windows 10 Pro
OK Thanks Erwin,
hope next AC version can add a field like that
