Switch from plan view to 3D (F5) whilst maintaining same layer and renovation visibility
On my PC, when I am in plan view, I can press F5 and view the model using the same layer and renovation visibility as just shown in plan.
On a colleagues PC pressing F5 in plan view shows the 3D view but with layer and renovation visibility from previous session.
Any idea how this setting can be toggled?
Thanks in advance.
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
LucaP
When you have 3D tab open already you could, while being on the floor plan, hold Ctrl button and click on the 3D tab. It should open with all the settings you had on your floor plan (or any previous tab for that matter). It always works the same - holding Ctrl button picks the settings of your current view and applies to the view you're opening.
Łukasz Pietraszko
ArchiCAD 28 PL, since AC20 | WIN 11 Pro
Intel Core i7-14700K 3.4 GHz | 64 GB RAM | NVIDIA GeForce RTX 4070 SUPER 12 GB | 2 TB SSD
Lingwisyer
Guru
There is an option to set it within the shortcut settings.
Duplicate Thread
Ling.
