2024-12-11 10:26 AM - last edited on 2024-12-11 10:28 AM by Barry Kelly
Hi everyone,
I recently started trying to write functions in Archicad.
Can you help me where is the error in the following function?
Thanks in advance for your help.
Solved! Go to Solution.
2024-12-15 09:18 PM - edited 2024-12-17 02:02 PM
Try a ; (semicolon) character after "Megnevezés" instead of a , (comma) character. You always have to use the same character everywhere in expressions, depending on your operating system settings.
In English language operating systems, . (dot) is used as a decimal point character, so in the Expression editor you can use the , (comma) character.
However, in some other language operating systems (like Hungarian), the , (comma) is used as a decimal point character, so in the Expression editor you have to use the ; (semicolon) character.
