Project data & BIM
Table of Contents
Lasha97
Can I create a table of contents in ArchiCAD that can be easily modified? If so how?
CosminF
If you are referring to the list of layouts, you can look into project indexes.
https://help.graphisoft.com/AC/19/INT/AC19Help/03_2_Views_Virtual_Building/03_2_Views_Virtual_Buildi...
Cosmin Furdui - architect @ Wincon, based in Romania
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
1 REPLY 1
CosminF
Setup info provided by author
