‎2017-03-31
11:32 AM
‎2023-05-30
12:37 PM
Rubia Torres
‎2017-03-31 08:07 PM
‎2017-04-01 12:56 PM
Richard wrote:
It sounds to me like you may be misunderstanding what the tabs do and how they work....
A single click on these is like jumping around in the Project Map, and a double click is like working in the View Map
‎2017-04-01 05:16 PM
‎2017-04-23 05:54 PM
Richard wrote:I’ve taken a more serious look at this. Although I seem to be the only one who’s struggling with these, my problem had to do with the way generic (non-view) tabs behave.
.. it's not completely clear from your post what is actually annoying you, or what you think has changed from past versions.
‎2023-03-29 02:22 AM
Hi Guys,
I think I am commenting on the same topic as above.
So when I select certain layers to be visible on say a Worksheet or Storey, when I navigate via the project map on the right to say another Worksheet or Storey I retain the same layer visibility.
This is good.
The problem is when I navigate between 2 Worksheets or Storeys using the tabs at the top, the layer settings don't update.
How do I fix this? This is killing me.
On a similar note, is it possible to have trace references use a different set of layer visibility options to the working space layer settings?
Thanks
‎2023-03-29 02:58 AM - edited ‎2023-03-29 03:00 AM
You can right click on a tab and 'link' them so they all keep the same layers.
Sure.
Just choose a trace reference from the View Map.
