Still against ? I certainly never said I was. Of course they have their place.
You make your case rock solid and perfectly clear by saying that what I am doing would be only a subset of the ways you need to work with ArchiCAD.
This is the only response necessary for all those who also need to use ArchiCAD in more ways than I do.
In the case of the Stair-
"I cannot copy the stairs for the buildings in Beijing to a building in Wynwood nor a house remodel in Puerto Rico or to an Emergency Room remodel. The IBC Codes are different in each locale and version 2009 (PR) is more stringent than 2015 (Miami) so if I copy from one to the other I might violate code. Parking requirements in Miami are more stringent than in Puerto Rico so copying and pasting from the latest PR project to the one in Miami can be a mistake and should be done with caution."
The idea of using pre modeled Stair assemblies is that they have all the necessary elements to simply be adjusted quickly for new conditions.
More quickly in many cased than you can configure the Stair Tool and it will never be exactly what you need if you are making detailed drawings and material schedules for the Stair. This is why even very simple Stairs are more useful when modeled with individual, highly adjustable elements, which include some complex profiles.
Presumably you have completed many projects with a Steel Stair, a Concrete Stair, Wood Stair, Stone... you can understand I am sure that if you did have similar Stairs already modeled, you would not keep them in Favorites, and they being able to reuse them because they are highly adjustable would be a a very big savings in time.
Regardless of building codes, all Stairs of a similar type have similar fundamental components and they could be modeled in a way that makes them very easy to use again.
The Stair is just one example that is typical of the entire building model.
If you have completed projects that are very detailed with highly adjustable elements, carefully chosen for how they function, not for what they are called, and configured specifically for reuse, you would understand better why I use ArchiCAD the way I do.
Using pre modeled assemblies, using multiple instances of ArchiCAD,
modeling everything with the intent of using it over in many projects, letting unique file structures evolve as you work, starting new projects with a file that is very close to being tailor made... these things are legitimate reasons I don't use a conventional Template or its corresponding Workflow.
Add or improve certain functionalities to the program, and some of my reasons for working the way I do with ArchiCAD might evaporate.
My final answer to the original question: Maybe you don't need to update your 3 year old Template. Maybe you don't need to use a Template at all?
I apologize for perhaps not reading all of the posts that might have been important to read. I have actually only read a few of them and my posts have been about those.
Also, I have just noticed that the question was in the category of BIM Managers. The category automatically implies the context where working without a Template is unthinkable.
