Template from project
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2018-04-12 11:18 AM
ā2018-04-12
11:18 AM
I have a job containing elements which will be modified to suit the site but they needs to be presented consistently on all jobs. I thought about saving as a .MOD file but this deletes all the views (sections, elevations etc).
Labels:
- Labels:
BIM Management
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-04-12 11:21 AM
ā2018-04-12
11:21 AM
You mean delete the model, but keep the views?
Turn off the layers for sections and elevations, use marquee bold to mark the model and delete across all stories, go through the views to clean up anything left that you do not want and possibly remove layouts.
It should take a few minutes at most.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-04-12 01:51 PM
ā2018-04-12
01:51 PM
Thanks Erwin, that sorts the view aspect. The next challenge is things like profiles, material & textures which are irrelevant.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-04-12 02:14 PM
ā2018-04-12
02:14 PM
Have you tried Purge Unused in Attribute Manager?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-04-12 04:15 PM
ā2018-04-12
04:15 PM
kzaremba wrote:This will remove everything for the most part.
If you have used a naming standard to differentiate standard template things from project specific, this is easily done in attribute manager or if you look at internal ID number, ussually this numbers up.
As a tip: we have dummy attributes for all things (layers, complex profiles, surface etc etc) with a high internal ID, causing new attributes to start at this new high number and up.
www.leloup.nl
Windows 10 Pro
www.leloup.nl
Windows 10 Pro
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2018-04-12 07:32 PM
ā2018-04-12
07:32 PM
Thanks for the suggestions. I will give them a go.
