‎2018-10-30
03:35 AM
‎2022-09-23
01:46 PM
Oleksandra Vakariuk
‎2018-11-01 06:47 PM
‎2018-11-02 04:00 AM
ron wrote:Hi ron
did you save your new scheme with a name and then apply that scheme. I always name my scheme after myself and the date of the new scheme so that I know the last time I modified. If I make any changes while working it will say custom so I then save with the new date and apply it
‎2018-11-02 07:09 AM
‎2018-11-16 03:17 AM
Stress wrote:Hello Marc,
Just to verify the steps.
1. When you are in the "Workspace Schemes" ...
the Stored Scheme should have changed to "custom".
2. Highlight your stored custom scheme (RCA Profile 22- for me) and redefine it.
3. Then go to your Work Environment Profile and check to be sure that the "Workspace Scheme"
is the one stored in your Custom Profile 4. (RCA Profile 22-for me).
To change which schemes are stored with each Profile, you have to
select the profile in the stored Profile list and click the Edit button.
‎2020-07-02 08:23 PM
‎2020-07-04 08:54 PM
‎2022-06-30 07:16 AM - edited ‎2022-06-30 07:36 AM
I'm having a similar problem. I defined all my preferences, saved it as a new work env. profile, I even went and saved each sub-category and made sure that the new profile refer to these (see below), applied schemes of profile and set as default, but no matter what I try, whenever I reopen AC or apply my preferred profile, the SO palette is gone. Frustrating.
Even tho my work environment is set to the preferred workspace schemes (AC24 TW on the screenshot), if I apply the profile again it changes to custom.
AC24 v7000-1.0 Windows.
