Project data & BIM
Unlocking AutoCAD format import...
I am trying to import an AutoCAD drawing but when I bring it in everything on the drawing is grouped together. I unlocked all of the layers that seemed to be locked but still cannot manipulate elements. I've also tried exploding everything but that doesnt work either. Does anyone know how I can get this done?
5 REPLIES 5
Upon trying to figure this out, I found that I need to somehow explode an xref file... the program is telling me that what I am selecting is an uneditable xref file. Can I work make this editable somehow?
In order to edit the elements, you need to 'Bind' the XREF in XREF Management.
You also might need to Ungroup to get the bound XREF manageable.
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Eduardo Rolon
either use Ungroup - ( not recommended for "big" drawings)
or use - Suspend Groups
For the Xref go to File-> External Content-> Xref Management
select the Xref and select attach
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
In AC09 Xref is under File-> Module and Xrefs
oops
AC29 US/INT -> AC08
another Moderator
another thing to do after binding/exploding....do a quick purge and audit...get rid of alot autocad junk....
