‎2007-09-05 05:18 PM
‎2007-09-05 05:49 PM
‎2007-09-05 06:58 PM
‎2007-09-05 07:21 PM
‎2007-09-05 07:57 PM
‎2007-09-05 08:09 PM
Tom wrote:Are you trying to do this through the built-in title types or through your own GDL work?
The challenge occurs with wantingbothview ID and layout ID in the same title type - ArchiCAD allows you to toggle between the two but so far I can't figure out how to have both....
‎2007-09-06 02:43 AM
‎2007-09-06 04:06 AM
Tom wrote:it looks to me as though the title objects pull information for "AC_DrawingNumber" in some hard-coded fashion based on whatever selection you have made in the 'Drawing ID' field of the drawing settings dialogue. i can't see any documented global variables or requests that let you get to it either . . .
I am writing the GDL code and have it all written except for a way to pull the view ID from the project map. Is there a variable for the view ID or reference ID? I tried all the autotext options but they seem to want to pull info from the layout, not the info from the project & view maps.
‎2007-09-06 05:16 AM
‎2007-09-06 03:19 PM
Rob wrote:Yes and no.
Tom,
I have run into the same problem lately (trying to do exactly the same) when updating our drawing titles. Apparently <DRAWINGID> is a virtual variable so it just copies and displays the value from the source as set in the Drawing Settings/Identification Tab. I have tried to use Drawing Name (when set to Name+ID option) to split the string up but the nature of autotext feature does not allow any string operations over it. So in other words the autotext (<ANYTHING>) variables are beyond the rich of GDL in terms of their content modification.
