Project data & BIM
Wall Composite? Pic 1
I'm wondering whether I can control the 2D Represetation of Wall composite at different scale
Pic 1 is the the way I want at general plan/scale
Pic 2 is the way I want at partial plan: showing more detail with brick fill and layers of render outside (Please see the next post for this image)
Anybody know how?
Please advise
Thanks
12 REPLIES 12
Erika Epstein
Braza,
I was thinking the same way, MVO. It won't give you the option of fill type, but the solid with or without the separator lines has worked well for me. I use this for smaller scale drawings as the fill pattern is usually not necessary.
Barry's suggestion of Core only display would also work well at smaller scales.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Yeah, I didn't mention MVO since Tran could not get the brick fill that he wanted...
Thanks guys,
I am aware of Model View Option but as Kahn already mentioned, I need to have control of fill type (brick type).
I think this is it.
Thanks all
Cheers
