Walls not joining properly
Ok, this is a bit of a mystery to me: both walls are the same (type, height, layer, etc), their reference lines meet (I turned them on for reference), wall skin priorities are okay (10 for studs, 8 for drywall), and yet the drywall on the exterior face is interrupted. Am I missing something? Is this yet another corrupted file? Anything else I might've forgotten to check?
3 Replies 3
Thomas Holm
Try using the intersect command. Turn on all layers, check with Show all in 3d that there isn't anything that interferes (maybe from another story).
__archiben
if the wall skin priorities are correct in the composite's dialogue, check that they haven't been manually over-ridden in that wall's specific settings . . . :
~/archiben
b e n _ f r o s t
Thanks guys for the help. Apparently this was the problem on some of the walls (not all). Don't know how that happened - I'll need to check my wall defaults. So, up and running again. Thanks again.
