jussara_scarle
Window Schedule Marker ID
I am using Archicad 25. How can I make sure each window AUTOMATICALLY has a different ID and the ID's don’t repeat themselves even when the windows are identical?
1 Reply 1
You can set each ID manually yourself or you can use the Element ID Manager.
If you have not used the Element ID Manager before, you may want to read this post.
https://community.graphisoft.com/t5/Document-Visualize-forum/ELEMENT-ID-MANAGER-ORDER-ISSUE/m-p/3446...
