rob2218
Window Schedule with double letters - how to move doubles to end?
see attached.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
1 Reply 1
Try with a space or underscore in front of the single letters - i.e. _A, _B
That will force them to list first (depending on the sorting order in your schedule settings).
The same with numbers, you need 01, 02, 03 or _1, _2, _3 for when you get to double digits.
I don't like to use a space as you can't see it - I know that is the whole idea.
If you are comfortable with a space and you know it is there then that is fine.
