Project data & BIM
ZONES CATEGORIES
Working with AC23 somehow I have lost the ability to display yhe Zones Categories with their distinct colors.
The Zone Stamp displays correctly over the window background instead of the expected Zone background color.
Cant' find anything on MVO, attributes, environment or any place to bring the display color again.
Any ideas how can I solve this ?
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
There are some differences between AC20 zones to AC23 and specialy about zone categories.
Do you just work with AC23 ? What was your Archicad before ?
Did you check you have no graphic override and did check you don't use a trace reference ?
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
Christophe wrote:
Thanks Christophe,
The problem was a setting within the "Graphic Override Combination"
The Combination i was working had a Rule named "Zone Fills - Empty";
when I removed the Rule, the Zones color showed up.
Hello Conrado Domingue,
Thanks about your feedback !
Christophe - FRANCE
