Project data & BIM
Zone Selection Settings is greyed out
Yh1CKAEN
Hi all,
I tried to use zone selection settings to update parameter of the element I had selected. However I found that the "OK" button was greyed out so I could not able to save any changes. May anyone suggest a way to unlock it? Thanks.
You have 2 zones selected.
Is one of them locked, or maybe the layer they are in is locked?
Yh1CKAEN
Hi all,
Found out the root cause is the layer they are in is locked. After the layer is unlocked in Layer Settings it's ok to change parameters in the element now. Thanks.
